2004-04-27 06:16 PM
2004-04-28 05:44 AM
2004-04-28 10:46 AM
Stuart wrote:just tried it and it sticks here . . .
In Display Options -> Options for Display & Output -> Fills: the setting reverts back to "All to Vectorial Hatching" whenever the file is opened.
2004-04-28 02:57 PM
2004-04-28 03:04 PM
2004-04-28 04:34 PM
2004-04-28 04:42 PM
Sometimes it might be better to retain your original settings (which in AC may be bitmap) but when would that be?Well, for example, in our current project, we have set up composites for the walls with hatches, but for small scale plans we would like to see a simple black poche, which we set up using the Display Options in ArchiCAD.
2004-04-28 05:02 PM
Stuart wrote:i doubt it - just do a 'save as...' with your current template. that's the somplest way of creating the file in the newer version format. but i didn't think that there was a version issue between v1 and v2 until i just checked . . . see attached.
Perhaps this is a v1 to v2 problem? The files with the problem were created with v1 but the one created with v2 seemed to work fine.
Does this mean I need to recreate my template file from scratch? Grrrr.
2004-04-29 08:28 AM
