Plots fills, lines, text as if there on the same plane.
My workplace is having a fill/plotting problem. When we place a fill on top of another fill the plotter prints both fills as if it can't differentiate which one is in front of the other. Same thing with fills and text. Say you have text on top of a CMU wall fill, on screen its correct, but when we plot the drawing it plots the fill and text as if its on the same plane and prints them running together. Whats up with that??
Does this also happen if you print to PDF? If not, you might try printing from the PDF file instead. Don't know what would be going on otherwise. Sometimes printing is more reliable than "plotting", so you might look at this, too.
Richard
AC26 (since AC6.0), Win10
Djordje
Plotting?
Printing?
Version?
Build?
OS?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
