Pre-built landscapes?
I'm looking for a landscape, situated in the countryside. It doesn't need to be a large area, just somewhere with grass trees etc. so that I can place a small building ( tent ) within the correct context.
I'm not sure if there is such a thing, but where could I find a landscape terrain ?
Thank You !
Steve Jepson
do a search for 3dmax landscape. You can import that to ArchiCAD.
Thank You. I've downloaded the Architerra plugin but it's not working for me... I will most likely use the 3dmax models anyway.
Just found this video on Youtube. If I knew it was this easy I would have already done it !
Terrain tutorial
