Printing pdfs in publisher
We would like to be able to print an entire viewset with individually filenames without having to enter a specific name for each view.
With the Amyuni it seems possible to print to pdf with names referring to the models filename with an option to add the date to the name.
Is it possible to print the entire viewset -or selected views- to pdfs with names referring to the views name instead???
1 REPLY 1
Link
If I understand you correctly, you can do this with PM's Publisher. Just set the Viewset Publishing Properties to Print, then click on the folder and go to Print Options. Set Amyuni, and in it's properties you can define what the PDF is called. Otherwise it will simply be called what the view is called, and you can rename those to whatever you want - either in ArchiCAD or PM's Publisher.
Hope that helps.
Link.
