Starting August 6, 2024, TLS 1.2 will be the minimum required protocol version for Graphisoft products and services that require an online connection. Learn more…
Problem connecting walls
I've just started working on an new project and I've got a problem with three walls I'm trying to connect to each other. I'm posting a picture of my problem.
EDIT: The lines in the picture is a AutoCad drawing.
________
Chrysler uconnect specifications
If you connect the walls with the reference (bold) lines as the drawing below it should work correctly. Make sure the vertical wall is set to the centerline method of construction.
Turn on the reference lines in the on screen view options to help you.
Thank you Peter!
You help worked!
Guess I owe you one
Thank you once again
________
L66 engine
No problem, glad it worked!
