Problem intersecting two different composite walls
ricardord
I am having trouble intersecting two different composite walls in an internal corner: they intersect perfectly in an outside corner as can be seen in the screenshot below.
Is there way to sort this?
Thanks
Ricardo
ArchiCAD 22 Solo – MacOS 13.7.4 > Mac mini M1 . 16GB RAM
ricardord
I've solved this by extending the brick wall to the inside of the rendered wall and adding a wall end to it with 4 skin turns.
R
DGSketcher
Legend
Interesting solution, thanks for sharing!
I have in the past resorted to complex profile columns for tricky wall connections.
Have you looked at the strengths of the Building Materials used for each skin of the composites?
