Problem with Solid Geometry Operation
Hi, I am trying to Subtract Profiled Beam and Wall from a Slab. Its Coming very clean in 3D and Section view but in Plan View still the cutoff geometry contours (Beam & Wall) are visible. Any one can tell me how get clean shape in plan also?
4 Replies 4
SEO's only show correctly in 3D (sections and elevations).
They do not make any difference to the floor plan view.
You will need to add your own lines and fills (or the patch object) to make the 2D plan look correct.
Hemanayal,
How about putting the components that you don't want to show on a Layer that you can turn off.
NCornia
Graphisoft Alumni
Graphisoft Alumni
see below
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
NCornia
Graphisoft Alumni
Graphisoft Alumni
One way that may or may not be less painful depending on the situation:
SEOs saved as an object will display correctly in 3D, elevation AND floorplan. Plus you don't have to worry about screwing up the SEO relationship if you move one of the involved elements.
Create the SEO and save it as an object and place in project. To retain wall/slab interaction with model, place a dummy wall/slab in same place as newly formed object, but place them on an invisible layer.
Of course this method is not perfect and has its own limitations.
Nicholas Cornia
ARCHICAD on Twitter
Tutorials
