Problem with curtain wall
I have a problem with the curtain wall. In the story view I can select the curtain wall, without manipulating it, unlike the perspective view where I can move it. I want to manipulate it in story view, because that's the only way to be precise.
And another question - I want to know how to make a single column to be horizontal.
4 REPLIES 4
Link
It looks like your wall containing the window may be set to Overhead All. Try changing it to Projected.
To create a horizontal column, use the beam tool instead.
Link.
Thanks for the attention and for the help, but for the first and more important problem didn't work. I have no idea why, but it's still the same. I'll try to solve it however.
Sorry for the double post. It actually works! I wasn't paying attention the first several times, but after more tenacity I made it. Thanks!
Sasho, AC will work a lot better if you close all these Autocad windows!
Махни го тоя Аутокад, бе!
