Learn more
Paopao
Problem with roofs
Hi, I am havign a problem with two roofs interception, I can't make them meet properly. Here is a screenshot of the issue I am having. Annyone can help, please?
Thanks
Pao
AC26 EDU • WIN 10 • Intel Core i7 2.8 GHz• 32G RAM• NVidia GForce GTX 1080
8 Replies 8
Did you use "connect > connect element to roof / shell" , "solid element operation" or "connect roof to single pan"
I invite you to use "connect > connect element to roof / shell" :
Christophe - FRANCE
Formateur Archicad indépendant à NANTES
Archicad 15 to 29 FRA FULL
Paopao
Yes I have used that command but the problem persists.
Paopao
I have also tried the solid elements operators but without success.
Share your pln 😉
Christophe - FRANCE
Lingwisyer
Guru
Could you select your roofs, so that we can see the extents of each object?
Ling.
I would be guessing that the larger roof on the left has the trimming body set to 'Pivot Lines Down', so the smaller roof is trimming up to the pivot line.
Try setting it to 'Contours Down'.
Paopao
thank you all for your inputs. I have manged to solve the issue: I just moved the black vertex in line with the lower plane of the roof
It looks a bit weird in the 3D (that segmented reddish line in the angle) but it turns out OK in the rendering example
Paopao
here is the highlited roof
