Problems With Cutting Holes In Vertical Elements
Can anyone suggest a way of being able to 'cut out' a hole through the edge of a tapered wall? I'm trying to create a shelf that appears to have been cut out of a dividing wall which is at angle...does anyone know of a way to do this?
Eduardo Rolon
Use an empty window or SEO's. If what I imagine looks like what you want.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
Or maybe a niche from AC's Library.
