Problems With Elevator Settings
Could someone please help me out with the story height settings in the elevator object? Is there an option that allows me to change the floor to floor height..and consequently where the doors of the elevator appear. As at the moment i have doors inbetween floors and cannot see an option that changes this..Any help is greatly appreciated.
2 Replies 2
Laura Yanoviak
The best advice I can give you is not to use this object. Use a 2D symbol for the cab, model the shaft walls and insert door objects as needed. Also, you may want to take a look at this post.
Hahaha it seems as if iv found the one thing with archicad that drives everyone menthal! Glad to see im not the only one...thanks for the advice though.
