MarinRacic
Problems with Interior Wizard - Gypsum ceiling
Is anyone using this add-on regulary without problems? I just can't get it to work! What I need is the plain 60x60 cm recessed gypsum ceiling which can be placed in a room which can be odd-shaped and I must be able to set the origin and angle... The documentation says nothing about it and trial-and-error method hasn't worked for me.
MBPro Retina 2.7i7/16GB/SSD
AC ...20/21
www.3Dart.hr
One important thing I learned is that you need to do the steps in order every time, not skipping any one of them, as data one step needs is generated based on the previous step. So after setting things in step one, do not go to step 3, go to step 2. If after step 4 you go back to step 2, then do step 3 again and then step 4.
Hope this might be it.
Laszlo
I've also had problems with this tool. After setting all of the parameters, the ceiling grid (I'm using 24" tile as the fill) always comes out askew. It's done that on two completely different projects, so I don't think it's something in the file. What am I missing?
