Probs resizing/scaling walls+roof
I have a simple massing model consisting of walls and a roof that I need to scale down a bit, when I try to do this using the rescale function the roof stays perhaps at the same height or up some distance about the walls.
Anyone know if there is a way to resize/scale the entire object together without this happening?
Select that elements, go to the 3D window (view from top) and save as OBJECT (non GDL!). Insert that object and then you can modify its dimensions.
is there any way to resize the model and edit individual parts afterwards? I've imported a dwg in a wrong scale but I did only notice it when I was trying to place trees and the model is rather complex already. Anyways, I'll need to edit the model later on. Can I explode the model and edit the individual parts after scaling? I've tried but didn't work, so maybe there is a trick?
Thanks!
Suse
