Profile manager
Hi! I have a question, there is a way to choose the direction of the profile manager when is used with a magic wand around a circle?
Thanks
4 REPLIES 4
Dontknow
When you use the profile as a Wall you can 'flip' it.
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
thanks but I used like a beam for a dome
Seems like you can't, the generated Beam's Reference Axis will always run counter-clockwise.
What you could do is play with the Offset setting to put it on the desired side of the Reference Axis. But the direction will stay counter-clockwise.
Thanks for your replay
