2005-02-17
03:47 AM
2023-05-30
02:41 PM
Rubia Torres
2005-02-21 02:33 AM
2005-02-21 02:37 AM
Have I failed to sacrifice sufficient goats to GOD CAD?The latest requirements state 17 goats.
2005-02-21 03:50 AM
Erika wrote:I can't get a different breakup of segments like in your screenshot, it's always the same.
The attached screen shot shows 3 different profiler objects made from the same 'C' shape . The left was set to 72, the middle 18 the right 8.
2005-02-21 03:20 PM
Ray wrote:Do you have the Tracing Method set to
I can manage to get profiler to work fine and the direction is not a problem, the only thing I'm having trouble with is controlling the resolution. Changing settings in Magic Wand Settings is having absolutely no effect on the result. No matter what I have magic wand settings set to, the curved part of the path comes out with the same number of facets.
2005-02-22 12:51 AM
woodster wrote:I've tried both, also making no difference.
Do you have the Tracing Method set toLinear Segmentsor Best Match?
2005-02-22 01:29 AM
2005-02-22 01:55 AM
woodster wrote:Woodster,
You've got to write down step by step what you are doing as you create the profile. Start by setting the Magic Wand dialog box (Tools/Magic Wand Settings...) as shown.
Then tell us step by step from there what you are doing. This works every time![]()
2005-02-22 12:19 PM
Ray wrote:
When I look at your image it seems that there are fewer than 36 segments along the curved part as you would assume there should be. Because I was getting similar results to yours and couldn't seem to make this smoother, I tried going the other way to make less segments to see if I could force it to be coarser (to test wether magic wand settings was actually making any difference at all), but it didn't change the result.
2005-02-23 12:13 AM
woodster wrote:Thanks Woodster,
Ok, you got me going on this one and I tested it out. You are right in that the Magic Wand settings are not affecting the number of segments as they should ......
It's a bug!
2005-02-23 07:19 AM
Ray wrote:sounds like fun while it lasted.
For a while I thought I was in my own little mixed up world.
