‎2005-02-17
03:47 AM
‎2023-05-30
02:41 PM
Rubia Torres
‎2005-02-23 09:49 AM
Erika wrote:Erika,
bug checks out here too.. today. But then why was it working correctly for me the other day?
‎2005-03-16 06:49 PM
Ok, you got me going on this one and I tested it out. You are right in that the Magic Wand settings are not affecting the number of segments as they should but they do affect the number of segments.This is a bug. The easiest workaround to control the resolution is to open the library part created by Profiler, look for the 'RESOL' statement in the scripts, and modify the value there.
‎2005-03-16 09:44 PM
‎2005-03-17 12:53 AM
gkmethy wrote:I believe that the resol has no effect when you've made a tubular profiler object as Peter Devlin has said - the polyline profile and the space curve path are defined in a TUBE object.
.....The easiest workaround to control the resolution is to open the library part created by Profiler, look for the 'RESOL' statement in the scripts, and modify the value there.
‎2005-03-17 02:32 AM
‎2005-03-17 05:10 AM
‎2005-03-17 05:31 AM
‎2005-03-17 05:41 AM
‎2005-03-17 05:57 AM
‎2005-03-17 06:23 AM
