Putting a flat end cap to the curtain wall
There are two option of curtain wall frames. One is Generic and the other is butt-glazed.
Currently I am experiencing with butt-glazed and I try to insert a flat cap end.
The photo is however the minimum I can get.
Is there an option to insert flat cap end?
Here is the photo for your reference
Instead of using using an accessory to place the end cap, use a different frame with a cap built in. 'Modular Frame 15' should do what you want.
If you need the external cap to have a different material to the interior frame, then Laura and myself both posted identical custom versions of that object. Either will work. These two threads should explain how to add it to your library -
http://archicad-talk.graphisoft.com/viewtopic.php?t=30641
http://archicad-talk.graphisoft.com/viewtopic.php?p=159714
Hope that helps!
