Question about slabs
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2008-02-29
12:23 AM
‎2023-05-25
05:53 PM
Rubia Torres
This same problem occurs when I use the magic wand with a slab and remove some of the slab. I am then stuck with thin lines that are left over. These might appear around construction lines I have use to form boarders. You don't realize it until you look at it in the three d view. Then it is quite obvious that it did not remove all you thought it would. This is in version 10
As a second part of this question, I can start my hole cutting in the middle of the slab or at an edge but I can not start the hole cutting at a node as the pet pallet opens and does not allow you to cut the hole. Thanks Doug
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-02-29 12:35 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-02-29 12:37 AM
dougw2007 wrote:Select the icon with the minus sign (-) from the Pet Palette, "Subtract from Polygon", and you can cut the hole.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-02-29 01:04 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-02-29 01:33 AM
Instead finish
Whereabouts in Idaho are you?
Link.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-09-06 03:06 PM
Thanks.
Ian
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-09-06 04:14 PM
Select Slab.
With the Slab Tool active, SPACE-click circle.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-09-07 08:25 AM
for the help.
I just created a little list with the steps to help other new archicad users.
here you go.
Ian
1. draw circle on plan
2. select slab
3. click on edge of slab to have the edit options
4. select in new pop up menu SUBTRACT EDIT
5. hold down space button and select new draw circle.
BANG----
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-09-07 10:27 AM
Or you can just SHIFT-click inside that Circle.
