Questioning the logic of the program
I have been using ArchiCAD for a little over a year now and I am still finding new frustrations everyday as I work. Many of these issues have been resolved by patiently understanding the peculiar process as to correctly draft and model in the program. One issue that seems to be recurring is the general logic as to how the program represents the user's drafting requests. In particular, I find frustration that a program made to accurately portray the actual details of construction down to the sixteenth of an inch on window trim, seems to be completely bamboozled when it comes to something as pedantic as joining walls together in plan. If I want to accurately represent my framing in plan, then why does ArchiCAD insist that there should be a layer of gyp. that runs inside my wall cavity?
I understand that there are all sorts of tricks, work arounds, techniques, proper drafting/modeling standards and parameters that can sort out all sorts of messes. But my questions is why? Why can't there be a straightforward solution to such a simple problem? This is the issue I keep running into, there are no simple solutions. Please help.
16 REPLIES 16
Yes, of course. I forget it is always about that one button...
I always have that one button checked, I've never run into a situation where I would want it not checked.
Which brings to my initial question of the logic of this program. I am not sure as to what is intentionally designed into the program and which idiosyncrasies have just been absorbed as a part of the program.
For example, why is there an internal logic as to how objects are layered while drafting? I draw a fill, and it is automatically drawn below my slab, though I drew it to highlight an area above my slab.
I draw a curtain wall to fit within the empty window opening in the wall. But yet, the curtain wall is drawn below the fill layer of that window opening.
I know these are minor quibbles, but if ArchiCAD is designed with these aspects in place, then where is the extra layer of control so that the user can adjust these norms to fit their drafting standards?
The program does not know why you are drawing a fill. It places it in a display order. You just have to bring the fill to the front of the display order.
See the below article on what element default display order is.
http://www.archicadwiki.com/DisplayOrder
You will see a fill has a lower display order than a slab, so it defaults to be hidden behind the slab. This logic was thought out, and explained.
I haven't ever used the curtain wall tool, but an "empty opening" is a type of opening, as is a curtain wall. So I don't believe there should two different types of openings in the same area. Maybe that is the explanation?
In response to the curtain wall:
I completely agree that it is very silly to put an opening inside another opening (as in a curtain wall in the same location as a window opening) but as far as I can tell, this is the only way to insert a curtain wall into a framed wall.
If there is a better way to do this then please let me know, from trial and error, this method seems to be the way to go.
And regarding the display order, this goes back to my initial question of why. I understand that ArchiCAD has a built in display order system, all I would like is greater utility and flexibility within that display order system. Something as small as an adjustable number attached to an object so that I could qualify the location of that object within the display order range.
Or, even better, the ability to change the preferences of how those display orders are arranged. I personally would prefer to have fill and line information to be above my slabs and walls, considering that I am adding that information for the final printed sheets.
I understand this is a small wish list, but what I am really looking for is a discussion on why the program is designed this way (flexibility in some areas and stringent stubbornness in others) because I seem to be missing something here.
Showing my ignorance with the curtain wall tool .... I had to look it up, never used it before.
The curtain wall tool is a wall (who'd have thought?), and therefor does not need to be inserted into a wall. It's not like a window. You do not need to insert it into an opening. Treat it as a separate wall.
You can create a "wish" post to have flexibility with the default display order of elements. Personally I don't find it too hard to send something to the back or move it forward in the display order. I actually created a custom toolbar which has those buttons in it so it's quickly accessible.
