Bruce
Railing tool post display funny business
I have encountered what I am pretty sure is a bug in the railing tool...but I could just be missing a setting. Steps followed:
1. Create a straight static railing with 4 nodes, including the end nodes.
2. Change one end node vertically.
3. The post next to the 'bent' node will disappear.
See series of screenshots below.
Bruce Walker
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5060 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
16 Replies 16
Bruce
Move end node vertically
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
Bruce
Post disappears, but node remains. Cannot re-insert post onto node - option not available
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
Bruce
New node inserted. Post appears at old node, but not at new.
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
Bruce
New node added on other side of working node - post appears as it should.
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
sinceV6
Hi.
Both the stair and railing tools have a myriad of settings. It's a bit difficult to know what's going on without the whole context. Still... my best guess is that this is related to your segment and inner post's settings.
Check this video by master Eric Bobrow (and the other 2 new videos in his channel). There are some useful tips in the segment settings that might help you troubleshoot this.
Please post back if you fixed it, so other people searching for the same can see a solution.
Best regards.
Bruce
Thanks sinceV6 - I've seen Eric's videos, which are a good resource. However, these are not Segment: Inner Posts, but Node: Posts. They should appear at every node.
If the handrail is cranked in plan - no problem. If there is no vertical crank - no problem. As soon as you bring the nodes in line so they form a straight handrail in plan, with a crank in the vertical plane, posts will start to disappear.
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
Do you have the latest update for Archicad?
I just had a quick look in build 5002 and I am not seeing the problem.
Bruce
No, I haven't updated yet. I'll give that a go to see if it fixes the issue. Good thinking.
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
Bruce
I have updated to 4022 NZE (the latest for my region) and it now works ok.
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
