Railing tool
Lasha97
Based on your experience, can I use ArchiCAD's Railing tool to create an almost identical fence, including its slope?
CosminF
Hi!
Wouldn't it be more resource-efficient to just make a "plain" model and apply a alpha-channel texture with the tiny wiring on top of the base model? (i.e. something akin to the fence chain link texture in the basic library)
I assume making it out of railing would generate a very complex geometry and maybe it will unnecessarily take up space in your model.
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
Create a custom balustrade to get the kinks and then add rails where required.
But as CosminF suggests, you may take a big hit in machine resources with all of the polygons it will generate.
Barry
Setup info provided by author
