SOLVED!
RailingTool: Double corner posts and cables
4hotshoes
I have designed a railing with double corner posts and I don't want the cables to run pas the post, but the top wood rail needs to connect at the corner. Is there a way to tell the cables to stop at a post? With out having to draw two separate railings that don't join at the corner?
Of course it makes no sense to have the cable bend 90 degrees at the corner in real life.
Todd Oeftger
AC27 Mac MacBook Pro 15", 2019, 2.3 GHz i9, 32GB, Radeon Pro 560X 4GB, 500GB SSD, 32" Samsung Display (2560x1440)
1 ACCEPTED SOLUTION
Solution
You can find it in the Railing Connections Settings.
1 REPLY 1
Solution
