Railings AC22
good day all,
I have tried every setting that i can try to attached a plate on a railing connected to a wall or column and can't manage it, is this something AC22 does ? if not can anyone tell me how to achieve this in AC22?
4 Replies 4
Hi!
Yes u can. All u have to do is to create your custom column in rail settings and put it there. Thus, u have to precise the exact position where u attach rail in ur column.
Happy easter
Or you could possibly add a very short and wide rail end.
I don’t have ArchiCAD with me at the moment but it should work.
thanks for your replies, i am not trying to create a column, what i need is that silver plate that attaches to the column
Pic attached - something to that effect
Lingwisyer
Guru
I believe rlalason's suggestion was to model those plates manually on the poles, hence the comment on accuracy.
Ling.
