Re:HELP!!!anotherBIG BUG
My ability to pick a line, edge, point, rotate seems to have decided to be offset by some arbitrary length. I can't rotate by picking the roof edge, wall ends because of this offset. I can't move an opening in the roof (for a skylight) because of the offset.
I don't know where to stop this, looked at mouse constraints, and everywhere else, but can't figure out what setting has been turned on, or what.
HELP
2 Replies 2
Eduardo Rolon
Check that you have not turned on Grid Snap.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Figured it out.
Had to change to Apple Magic Mouse (bluetooth); restart ArchiCAD (who knows why) and reset mouse constraints (somehow got changed to Mac-classic like) probably when I was in panic mode.
Had been using an early version "Magic? Mouse" that involved holding the "control" key to get a "right" click operation...which sometimes did not work.
thanks for all suggestions
Grid snap is not on, mouse constraints are "cad like" 5 pixels, any more ideas?...this is driving me nuts
