Re: Inserting jpg or tif in picture frame object in library
hi.
please somebody tell me how to insert different pictrure in the picture frame object library.
3 Replies 3
Aaron Bourgoin
see the attached screenshot:
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 29 / AC29.2.1 USA
Rhino 8.35 Mac
MacOS Tahoe 26.6.2
Aaron Bourgoin
sorry, forgot to say that the bitmap must be located in one of your loaded libraries - you are using a project specific library aren't you?
If you are just using the PLA library, create a folder, put the bitmap in it, and then load it as a library.
Rhino 8.35 Mac
MacOS Tahoe 26.6.2
Scott Bulmer
Aaron,
A user/client using AC10 has loaded her master library containing images and textures. She attempts to add an image from that master library to the Picture object in the filename box, but a warning is returned stating that the file is not found. Her master image/texture library has 13 subfolders and totals 138MB in size. She has confirmed that the file and name are correct and exist in the sub-folder. I am not experienced in this, but do you have an idea what she may be doing wrong? Thanks.
AC27 v. 4060 w/ MEP, Cadimage, Twinmotion 2023.2.2 using AC from AC6.0, 2021 MacPro M1 chip, Adobe CC. Used AC on both platforms.
