Rebuild selected from model
Tom Krowka
I am working in the S/E window. Have an element selected and want to rebuild only that element. The button for "rebuild selected from model" is grayed out. The S/E window setting is for manual rebuild. Have made modifications to a beam.
How do I get this to work? Don't want to rebuild the whole elevation, it takes two minutes to rebuild the whole thing.
Thanks.
Tom Krowka Architect
Windows 11, AC Version 26
Thomas@wkarchwk.com
www.walshkrowka.com
Link
Sounds a bit buggy Tom, but have you tried a 'Rebuild and Regenerate Autorebuild Model S/E'?. Do this by holding down the Alt key when accessing your Rebuild menu item.
Link.
Tom Krowka
Can't I do it with only a button?
Thomas@wkarchwk.com
www.walshkrowka.com
Link
You can hit Ctrl+Alt+Shift+R (or can you?! ), or create your own toolbar button. Still sounds buggy though.
Link.
