griggadee
Reducing File Sizes in Archicad
Hi Everyone,
Does anybody know how to reduce the size of Archicad files? For each new project I undertake, I typically copy and paste my file from a previous project, and then delete the 3d model and drawing sheets, and then start building a new 3d model in that file. This allows me to use all of the previous line types, and surfaces etc. that I am used to using. I know that I could spend the time to create a drawing template that I could use for all new projects, but I just don't seem to find the time to do this! Unfortunately, my file sizes are now hovering around 500mb!! Ouch! Is there any way to pge the cache or unused layers / info from files?
Any advice would be much appreciated.
Thanks,
Paul Griggs BSc (Hons) MCIAT MCIOB
Chartered Architectural Technologist
AC23, i5 3570K Processor, 16gb RAM, NVidia 570GTX Graphics Card, 250gb SSD Drive
14 Replies 14
griggadee
Top stuff, Lee, that's really helpful! I will make the time to do that this week, as my current approach is not viable from a storage point of view. Really appreciate the guidance. Thanks
Lingwisyer
Guru
The one annoying thing about starting a new template is recreating all of your sheets... Zzz...
Win11 | i9 10850K | 64GB | RX6600 Win11 | i9 11900K | 32GB | GTX2080TI
Keymaster
You can merge a file and put all it's layouts from an old template into the new one.
Mizan
Save a clean file in a .*tpl format.
parvink
Archicad files can get bloated over time, especially with your workflow. Try "Save As" a .PLA (Archive) to gather only used elements, then re-save as .PLN. Also, regularly use "Remove Unused Attributes" (under Attribute Manager) to clear unused line types, surfaces, etc. Cleaning up unused layers, details, and embedded objects helps, too. Long-term, definitely consider creating a custom template—it’ll save you lots of headaches!
