Reducing Mesh point heights by the same amount
Let's say I have a terrain modeled with mesh with different elevation for different isohypses. Is there a way to reduce the height of the whole model by certain amount without losing the geometry of modeled terrain.
I attached the picture, I want to remove the volume below the red lines.
Thank you in advance
5 Replies 5
David Shorter
I'm not sure exactly what you want to do here
do you just want to crop from the base up to the red line?
do you want to lower the whole mesh including the spot height?
I mean is it a cosmetic change or a real change.
How was the mesh created ? with contours or spot heights from a surveyors points file
Archicad 4.1 to 28 Tech Preview. Apple Silicon
you can't build a line
Mac Studio
iPad Pro
iPhone
David Maudlin
Azbogah:
The part you want to make shorter is the Mesh Height, its value can be changed: Mesh Settings > Geometry and Positioning: upper left corner of the panel.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thank you for responses, but maybe I didn't explain it properly first time.
Mesh Height adds the height BELOW the reference line. If it has 0 value, the height of the whole mesh is determined by the elevation of the mesh point(s).
I made this Mesh from the isohypses from the topography. For example if I give one line of points an elevation of 15 and the other 20, I will have the shape above the reference line even if Mesh Height is set to 0.
All I want to do is to reduce this elevations by, for example, 5 meters. So 15 becomes 10 and 20 becomes 15.
P.S. My name's also David.
Stress Co_
Select the mesh:
EDIT> Move> Elevate> Input: -5 meters
Marc Corney, Architect
Red Canoe Architecture, P. A.
David Maudlin
David:
In addition to Marc's advice, you could select the Mesh in a Section/Elevation window and drag it down 5 meters.
David
