Reference Starting Point
Zdenko
ac27
have been struggling to get consistent workflow on placing items from a reference point and then key-in a distance. in this example i want to start placing a line 11 units away from a selected reference point. i select the line tool and select my reference point to start from but nothing else allows me to key-in 11? there are times i get the input tool for D, X, Y etc. and times i don't get it. this is also true when i am working with doors, windows or walls? any suggestions, i have exhausted google search and nothing seems to come up.
Archicad 27 5030 USA Full Apple
M3 Max 36GB MacBook Pro
Sequoia 15.1.1
CosminF
You mean value input from the tracker? You may sometimes switch (even accidentally) between polar coordinates (with distance/ angle) and absolute (with x/y) with "/" key.
Or are you referring to the new feature, distance guides?
https://help.graphisoft.com/AC/27/INT/_AC27_Help/030_Interaction/030_Interaction-65.htm
Cosmin Furdui - architect @ Wincon, based in Romania
AC 27, running on Windows 10 Intel(R) Core(TM) i7-9700K CPU64, 3.60GHz, 16GB RAM, Nvidia GeForce GTX1650
Make sure the tracker tool is active (turned on).
Activate the line tool and hover the mouse over the point you want to measure from (do not click).
Type 'X' or 'Y' (depending on the direction you want to go), then type the distance followed by '+' or '-' (again depending on the direction you want to go), then 'Enter'.
That should establish the start point, now complete the line.
You can also use 'A' if you want a specific angle rather than horizontal or vertical (X or Y).
thank you both. i am familiar with "distance guides". my gripe is what barry describes but works inconsistently between different files or the same file. not sure what is going on but extremely frustrating.
Sequoia 15.1.1
