Llian
Reflected Ceiling Plan Roof Objects
Not sure what's happening.........why are the skylights [labelled 03] showing as overhead [dashed] lines instead of solid contour lines ? Everything else, ceiling fans, lights, are showing solid as they should be. Anything I need to know about skylight and roof on reflected ceiling plan ?? Thanks
Lilian Seow LEED AP | cSBA | CAPM | PMP
AC 29 USA FULL | Windows 11 Enterprise i5 3.10GHz | Archicad-user since 1994!
David Maudlin
Llian:
Is the Skylight placed on the Roof story or the Plan story? Are you using Project Preferences > Construction Elements > Floor Plan Display of Single-Plane Roofs and their Skylights: True 3D Projection or Symbolic. There are a number of variables.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
