Tom Krowka
Regeneration time
I am working with two windows open, section and plan. When I make a change in the plan, and back to the section, it takes about one minute, 45 seconds to regenerate. Is this typical? I am using the Open GL engine setting. Is there any other setting that might have an impact on regen time?
This machine has a 64 mg video card. Does that have anything to do the time issue?
It is a section through a two story house. Not too complicated.
Tom Krowka Architect
Windows 11, AC Version 26
[email protected]
www.walshkrowka.com
13 Replies 13
Link
My first question would be:
How long has the computer been running? It may be time for a reboot to clear the RAM.
My next question would be - do you have a particularly complex library part in the section? Or maybe 278 duplicate items?:-) Or maybe your section is infinite and you have a bunch of elements in the background that is bogging AC down?
Check those things and let us know how you go. In your Preferences>Imaging & Calculation you can check 'Write Report'. Next time your section ~rebuilds~, it will write a report that will provide some insight into what is going on. To view it, go to Window>Report. Maybe include the report if problems persist!;-)
Good luck mate.
Link.
Tom Krowka
Thanks. I'll give all those things a try.
[email protected]
www.walshkrowka.com
Tom Krowka
Link:
Tried the report scenario. Tried to include it in this reply. Every time I try to copy from the report(for copy and paste) ArchiCad crashes. Is there any other way to copy the report into this type of reply?
[email protected]
www.walshkrowka.com
Tom Krowka
Following is the report generated for the section. There are two generations. The first one has the vectorial hatch turned off. You can see the whole thing takes 15 seconds.
The second one has vectorial hatch turned on. The generation takes about a minute and a half. Of course, the obvious solution is turn the hatch off while working.
Question: Why would the sun direction have any bearing on the section if I have shadows turned off? It must refer to hidden polygon removal.
The pen number less than 1 refers to a pen I had set to 0, which is transparent. I guess AC doesn't like that too much.
Other than the above obvious turn off the hatch solution, any comments?
Beginning generation of Section/Elevation:
Start time : 2/28/2004 2:04:16 PM
Pen number is less than 1 or greater than 255
at line 93 of file hhd-Cornice80.gsm.
Document name : Judge.pln
Processed : 90 walls 249 objects 6 columns 10 ncBeams
66 slabs 0 meshes 37 pitch roofs
End time : 2/28/2004 2:04:27 PM
Elapsed time : 11 seconds
Creating section
Elapsed time : 0 seconds
Projection : Side view
End time : 2/28/2004 2:04:28 PM
Hidden line removal (analytic)
Start time : 2/28/2004 2:04:28 PM
End time : 2/28/2004 2:04:29 PM
Elapsed time : 1 seconds
Finished generation of Section/Elevation.
End time : 2/28/2004 2:04:31 PM
Elapsed time : 15 seconds
Start time : 2/28/2004 2:06:31 PM
Processed : 3 walls 245 objects 0 columns 0 ncBeams
0 slabs 0 meshes 6 pitch roofs
End time : 2/28/2004 2:06:32 PM
Creating section
End time : 2/28/2004 2:06:33 PM
Start time : 2/28/2004 2:06:33 PM
End time : 2/28/2004 2:06:37 PM
Elapsed time : 4 seconds
Hidden polygon removal
Sun direction : vertical 45 horizontal 45
Start time : 2/28/2004 2:06:37 PM
End time : 2/28/2004 2:08:00 PM
Elapsed time : 1 minutes 23 seconds
End time : 2/28/2004 2:08:03 PM
Elapsed time : 1 minutes 32 seconds
[email protected]
www.walshkrowka.com
Link
245 objects
That should set the alarm bells ringing!;-) Seems you have ~plenty~ of cornice. You may want to use 'Check Duplicates'. This is an add on that is found in your ArchiCAD>Goodies folder - you can load it using the Tools>Add On Manager.
Link.
Tom Krowka
Checked the duplicates, had only three in the whole project. If every door, window, furniture, tub, etc. is an object, 290 wouldn't be too many for an entire two story house; or would it. I don't know what else they could be. I do have a lot of cornice work. Not more than 20 -25 pieces, however.
The time must be in regenerating the hatching.
[email protected]
www.walshkrowka.com
Some objects, eg trees and vehicles slow the process down.
It looks like your pens settings need changing for your cornice object also. Select a pen from the AC pen palette at line 93 of the object settings.
OpenGL is not used in the section/elevation views and so has no effect there (AFAIK). The hatching always takes the longest and your report bears that out. Try the section without the hatching as a test. But, really, a minute and a half is not too bad.
To speed things up I usually distinguish between output sections with the hatching on and working sections (for editing the model) with hatching off. The output sections I unlink so that I can work on them without having to wait for the automatic regeneration and then batch process them when I need to. The working sections I just create and delete as I need them.
Tom Krowka
Once unlinked, can you link back to the model in any way? If not, what is the quickest way to handle a change within the model that you would have to make in the unlinked section? Overlay with the unlinked and move elements as required?
I'm trying to get some techniques established without the trial and error process to cut down the learning curve.
[email protected]
www.walshkrowka.com
