Check the Surface applied to the Object.
Then go to the Surface Settings Dialog and see if a 3D Hatch is specified for the Surface. If there is, set to to a solid background fill or something similar.
The other option is to turn off 3D Vectorial Hatching in the Section/Elevation Settings Dialog (which will turn off its display for all elements in that Viewpoint).
