Removing fill from objects
I have a question regarding imported object fills from SU2016
I created a roof and door element for a small project on Sketchup 2016, than converted it to SU 2008. I brought the object in to ArchiCAD 19 and on the elevations it shows some kind of fill. I was wondering how can I remove these fill lines. I have tried to open the object settings and a few other things but have yet find success in doing this. Any thoughts or ideas on how to do this?[/img]
1 REPLY 1
Check the Surface applied to the Object.
Then go to the Surface Settings Dialog and see if a 3D Hatch is specified for the Surface. If there is, set to to a solid background fill or something similar.
The other option is to turn off 3D Vectorial Hatching in the Section/Elevation Settings Dialog (which will turn off its display for all elements in that Viewpoint).
