2009-09-10 03:33 PM
2009-09-15 02:26 PM
KeesW wrote:Sorry if i'm missing something but can't this be (mostly) solved using the Layer Intersection Priorities in your Layer Combinations? I know there can still be issues connecting skins of complex composite structures, but hidden elements should never be affecting visible elements if these Layer Intersections are set correctly.
We have foud that the real issue with renovations is not layer control but things like junctions, priority intersections and similar issues that can completely stuff a drawing which contains new, demolished and old items. Archicad's inability to realise that 99% of users don't want gaps left in existing or new walls when the elements that previously joined at the point are removed or hidden causes inumerable, time consuming distractions. More intelligent defaults would help many users.
2009-09-15 03:22 PM
KeesW wrote:Have you tried using the Intersection group number control in the Layer setting's dialogue box? With the help of this you should not have problems with visible construction elements getting gaps because of the hidden construction elements.
2009-09-15 03:31 PM
Susanne wrote:
Hi
The best way to go about it is to have the demolished / removed construction layers with a different intersection number.
2009-09-15 05:56 PM
owen wrote:Agreed. I've been able to set up quite complex models, with layer combos using different intersection priorities, showing all of as-builts, demolition plans, and planned additions (in two or more optional variants), without any display or model issues.
2009-09-16 03:41 PM
2009-09-18 07:46 PM
Stress wrote:I've been using strategy #4 (existing PLN hot-linked to new PLN) for a few years and it works very well.
Read HERE AEC Byte's Tips & Tricks for Remodels and Additions.
2009-09-21 12:59 AM
2009-09-21 11:58 AM
2009-09-21 04:09 PM
