‎2012-02-13 06:30 PM
‎2012-02-13 10:08 PM
Tom wrote:I would usually use the eyedrop tool which is even better for me. Not only do I get to repeat my last command, but I can also repeat any command that was already implemented into the project (ie: walls, lines, objects... etc).
Is there a command for this.....repeat the last operation you did. For ex., you draw a line, then hit escape which terminates the operation. Now you want to draw another line. Anything which will automatically put you where you were before you hit escape? It would work for any command.
‎2012-02-14 12:58 AM
‎2012-02-14 01:05 AM
‎2012-02-16 10:31 PM
‎2012-02-16 10:57 PM
‎2022-04-03 01:54 PM
I am missing this in an other respect:
Let´s say you are in a conceptional design phase an just want to draw a bulk of e.g. walls or lines anywhere without thinking about where they should begin or end later on.
When it comes to adjust or intersect the objects (as one example) when you are happy with your concept you need to select those objects you want to adjust, activate the adjust command and select the one you want to adjust to....
Now you have to repeat this with hundreds of lines or walls or whatever....
Even "repeat command" will take too much time.
My proposal:
Activate "adjust" (shortcut or icon) first, command should remain active until "esc" command.
1-Select one or more objects by holding down "shift"
2-Release shift
3-Select target
4-Repeat step 1-3 until you are satisfied 🙂
hit escape!
A huge time saver ... or anything comparible will improve working speed and architects happiness!
