Arnaut_2604
Repeating Solid Command in 3D Script
Hi there,
I've run into the following issue:
I have a complex shelf which I create using INSCTGROUP.
But everytime I place the result, I want to be able to change the thickness of it by defining the Value of Z before placing it. Like you could do with Gosub
However it keeps the demensions of the first time I defined Z.
Killgroup leaves the Group empty so I don't know how to make this work.
The script is just as an example:
for i = 1 to 5
	addz 2
	Gosub "Block":
next i
del top
END
"Block":
	GROUP "Base"
	Block A	,B	,zzyzx+(0.1*i)
	ENDGROUP
	GROUP "Operator"
	Rotz 45
	del 1
	ENDGROUP
	Result = Subgroup("Base", "Operator")
	Placegroup Result
RETURN
Is there any way to get around this problem?
1 Solution
BrunoH
Hi Arnaut_2604,
Within a script each different group shall have a unique name, even if you kill a group you can't reuse it for a new one.
So you have to create a new name for each group.
You can use the i value to do this, see the example modified below.
for i = 1 to 5
addz 2
Gosub "Block":
next i
del top
END
"Block":
Cible = "Base" + STR (i,1,0)
GROUP Cible
Block A,B,zzyzx+(0.1*i)
ENDGROUP
Operateur = "Operator" + STR (i,1,0)
GROUP Operateur
Rotz 45
del 1
ENDGROUP
Resultat = "Result" + STR (i,1,0)
Resultat = Subgroup(Cible, Operateur)
Placegroup Resultat
RETURN
ArchiCad 3.43 to 28
MacOS Monterey
Go to post
BrunoH
Hi Arnaut_2604,
for i = 1 to 5
addz 2
Gosub "Block":
next i
del top
END
"Block":
GROUP Cible
ENDGROUP
GROUP Operateur
Rotz 45
del 1
ENDGROUP
Placegroup Resultat
RETURN
ArchiCad 3.43 to 28
MacOS Monterey
Arnaut_2604
Brilliant! Thank you!
Didn't know I could make a name which would change with every loop
