Replace Window Schedule
In the file I am working on, the Window Schedule shown under Schedules > Elements was completely messed up when someone else was previously working on this file. I have concluded that the only thing to do is delete it from the layout and from Schedules > Elements.
ArchiCad Help and a Google search have not produced any info on how I replace it with an "unused" "new" interactive schedule. Does anyone know how to do this?
Thanks in advance.
1 REPLY 1
If you know what is wrong with the original schedule you could just fix it up.
If not then you can create a new one from scratch or you can IMPORT one you have done in another job - you will need to EXPORT it first from that job so you can IMPORT it into your current job.
Then create a view for that schedule with the correct settings (layers, scale, MVO, etc.) and then add that view to your layout.
