ā2006-06-03 01:14 AM
ā2006-06-03 02:35 AM
ā2006-06-03 03:03 AM
ā2006-06-03 03:10 AM
ā2006-06-03 03:39 AM
ā2006-06-03 04:30 AM
ā2006-06-03 11:21 AM
habiatuq wrote:Yes, at least in 10 but not to the extent that the slab's dashed representation line doesn't represent the true extent of the slab. In AC10, walls can also be shown on several floors as you like, but then you'd get a line for both the inside and the outside of the wall.
Maybe if we can manipulate slab priorities.
Do Slabs come with priority settings? can we manipulate their priority to ditermin how they intersect with walls? H
ā2006-06-03 04:05 PM
ā2006-06-03 05:00 PM
Dr wrote:I don't. I prefer the wall height to be the actual wall height.. 8'-1".. 9'-0" whatever. If you make the wall taller to compensate for the slab sheathing and siding, then the wall is no longer accurate. I wrap the floor slab with a composite of sheathing and siding (or brick, stucco.. I have composites for all of them available. I put that on a layer called exterior misc so i can turn it off for the print view. This is also good for acccuracy if you are doing material take-offs. Where a porch might be, then you leave off the sheathing/siding strip. That strip goes to the bottom of the mud sill to the bottom of the wall. Doesn't everyone do it that way
We set our slabs (floor composits) to extend to the sheathing line, as they do in real construction. The wall extends to the bottom of the slab, or more accurately, to the bottom of the mud sill. SEO the slab from the wall with downwards extrusion, put in your mud sill and the model is correct. Siding is outside of the slab so it all shows properly and in section is correct. Doesn't everyone do it that way?
ā2006-06-03 05:13 PM
