2011-02-23 08:31 PM
2011-02-23 09:19 PM
2011-02-23 11:10 PM
2011-02-24 12:00 AM
2011-02-24 03:18 PM
2011-02-24 05:09 PM
zeropointreference wrote:If you export your work environment, it saves it as an XML document. Can you manually edit that and import it in again?
I think it would be an interesting notion if Graphisoft took on the philosophy of putting all those pref, config, and ini type files into editable xml files. It would be nice to get to the stuff there is no front end to. There are some xml files now so maybe some day they will?
2017-07-15 09:48 AM
