‎2007-01-31 09:39 PM
‎2007-02-01 07:47 AM
‎2007-02-01 03:28 PM
‎2007-02-03 07:46 PM
‎2007-02-24 03:53 AM
‎2007-02-26 07:42 AM
Chazz wrote:I'm thinking this must be an isolated case, as it goes against the polygon pet palette editing throughout all of ArchiCAD's elements. I've never found that a zone is linked to anything and they should be editable no matter what gemotry method is used.
If the zone shape was auto generated by clicking in a room, it is linked to that room. The only way to resize it is to move the walls and run a zone update. However, if you change the geometry method to manual (see below) the zone becomes editable using the standard polygon metaphors.
‎2007-02-26 02:33 PM
Link wrote:This was my memory as well: ALL Pollys could be edited, Zones included. However I ran up against the exact same condition as the poster described shortly before I read it and assumed it was a new behavior in AC10. I'm not in front of my workstation at the moment but are you saying you have been able to edit auto-generated zones out of the box? I will Test ASAP.
‎2007-02-26 02:53 PM
‎2007-02-26 10:14 PM
Chazz wrote:Yes - that's what I'm saying! Sounds like you're going to get a lot of use out of it!
... are you saying you have been able to edit auto-generated zones out of the box? I will Test ASAP.
--Chazz
‎2007-08-15 09:56 PM
Melisa wrote:Pleasant discovery: in AC11, you can edit the Zone even without it's background fill displayed.
Hi Brian,
It sounds like you need to adjust the settings in your Model View Options to make the adjustments and then set them back.
Go to Document / Model View Options /
Verify which one you are using and on the very bottom right corner set the background fill of the Zone to display.
