!Restored: Problems in hotfix 1200???
Is anyone else having problems with build 1200?
Since I installed it I have been having repeated kernel panics on my Mac (I haven't updated my Windows install yet). At first I though it might be a problem with my new Mac, but a colleague of mine is also having serious performance problems with 1200 on both his XP32 & XP64 machines.
I have reinstalled build 1114, and so far no panics. He is now reinstalling 1114 on his PCs.
12 Replies 12
Well...
It looks like I posted too soon. I just had another panic, but using build 1114 now. So maybe there is something wrong with my machine.
On the other hand, my colleague just finished reinstalling build 1114 on his IBM machines and AC is running much better.
I updated to MAC OS 10.5 and AC 11 build 1200 the same day.
2 issues :
- I don't know if it's ArchiCAD related, but I'm no longer able to use Hide ArchiCAD in Finder. Several attempts and AC is hanging >>> force quit
Other applications are doing fine...
- creating worksheets with the worksheet tool or unlink section / elevation, all vectorial hatchings get exploded AC 9 like ? ?
Update:
I removed the AC prefs files and so far no panic, but I did have a system lockup (endless beachball, no force quit option, no switching apps) requiring a hard restart.
Joeri wrote:
... I don't know if it's ArchiCAD related, but I'm no longer able to use Hide ArchiCAD in Finder. Several attempts and AC is hanging >>> force quit
Update : the same situation with AC10 / 3D window in Open GL mode is flickering... must be an OS 10.5 issue
Eduardo Rolon
Mine is behaving correctly but I am running it on a G5 so that might be a difference.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
I gather that even the mighty Dwight has been having some similar troubles. We both repaired our permissions and things got better. I had another kernel panic yesterday evening, but it worked all day after the permissions repair so at least that is an improvement.
Eduardo Rolon
Might be unrelated but check if this applies
archicad-talk.graphisoft.com/viewtopic.php?p=115828#115828
AC29 US/INT -> AC08
Another issue (OS X Leopard or hotfix 1200 related ???) :
while working in AC11, repeatedly the main toolbar on top is missing : instead the Finder toolbar pops up in front. ArchiCAD application is still active because I can use Navigator, tools, ...
Any ideas?
Thanks
UPDATE:
The permissions repair made things a lot better but I just had another panic this afternoon.
System update informed me of a firmware update for my Mac Pro so I have installed it. Hopefully that will fix things up.
