!Restored: Success = getting new customers
I saw some documents to compare between Revit and AC.
I study Revit from own website.
It is just copy from AC!!
I used to work with AC (and very satisfied, and like many friends from AC-forum).
As AC-user I hope, AC must be better than Revit for Architects.
I have not used Revit, but just seen from Website.
The web-site from Revit is so nice, that I must believe, Revit should be better than AC.
I like to know your opinions and also opinions from GS.
Thanks
368 Replies 368
Petros Ioannou
samsung wrote:
The best way to learn AC very easy is to try to be a good organised architect.
The best way to learn Autodesk is to try to be a good computer-expert or engineer.
ArchiCAD 22 4023 UKI FULL,
Archicad 21 6013 UKI FULL, ArchiCAD 20 8005 UKI FULL
iMac Retina 5K, 27-inch, 2017
4.2 GHz Intel Core i7
32 GB 2400 MHz DDR4
Radeon Pro 580 8192 MB
Basically, don't switch. You will not like what you will see in Revit. Revit is still to much "read me" software. By "read me" I mean there are no icons or symbols representing option in Properties. A lot of scrolling through the options. Everything is so compacted. I personally don't like the interface. And still some people say integrated, no updating necessary, but Revit experts tell me, If I will isolate part of the plan (some area) will it be isolated also in 3D ? No. Why ? Can I see in 3D just 1-st floor - NO, I mean yes you can, but it is so frustrating how to make it that it is almost pointless to use it. Ghrrr. Btw. Make a simple test. Draw a wall on a plan a have the 3D window open, you will not see the wall until it is created, same thing the other way. So where is the seamlessness here? Don't get me wrong, I like Revit, but it is still a teen.
Thanks Miki
Than it is no copy
The website of revit is so nice, I have feeling, with this Revit I can be rabbit in worderland.
I will go on with my architects tool ArchiCAD.
Who and why censored that word? Is that automatic? To all of you - the censored word is description of the kid between 11 and 19. t e e n .
TomWaltz
Yeah, the censoring is automatic on the board. Some words get filtered no matter what, usually ones with any possible sexual connotations.
Tom Waltz
Scott Davis
Typically, thats the way it works. you dont see things until you actually create them. Does this make sense to anyone else?
clicking "Orient to other View" is frustrating? Wow, if the simple things frustrate you.....
Scott Davis
Autodesk, Inc.
On March 5, 2007 I joined Autodesk, Inc. as a Technical Specialist. Respectfully, I will no longer be actively participating in the Archicad-Talk fourms. Thank you for always allowing me to be a part of your community.
I mean when you are creating ex. wall you see a preview how it will look, before you accept second node, but only in current window.
Scott you know it is not so intuitive, you have to activate 3D windows first (if model is complex it takes time) then use Orient (this is in my opinion not a small thing).Orient command is changing your point of view, and maybe I'm using it wrong but when I choose "Level 2" (from the standard starting settings) it shows all Level 1 and cut in half Level 2. And what if building have middle levels? This in my opinion is far more difficult to use than just selecting elements you want to see and activate a 3D window. My opinion of course. What Revit have is more similar to AC Cut planes but limited to only horizontal cut planes (although enhanced with interactivity).
I must laugh... It is not for me. 3D model with Revit, AutoCAD and AC is OK. 3D model is same 3d model.
But the method of working is very important.
Phase to phase is important. From concept and to calculating and to working drawing and BOQ, if concept changed, than automatically updated.
This concept from AC makes AC really powerfull, not for Frank Gehry Architecture.
Thank you, Miki
I know very well what you mean. The both programms are quite different.
~/archiben wrote:
.........as an archicad user i have a gut feeling that the revit engine is far superior. whilst the revit feature set may be lacking in some areas at present (my opinion)...........i believe that it will be able to accommodate much more future development than archicad's underlying technologies currently can.
~/archiben
Ben I value your thoughts on future of AC vs. Revit a lot. If what you say is correct should we be thinking about a transition to Revit in coming years? I am putting the future of my company on AC and would like to have some planning in order?
Thanks in advance on your input,
Joseph
stefan
As an ArchiCAD user with basic Revit skills, I appreciate Revit very much. I think that they might even have the best BIM integration at the moment, especially with the more direct updating, the element relationships and a well-thought out workflow. And they finally support IFC both ways, have connections with structural software and engineering and have a good graphical engine. And they seem to be improving nicely, despite the rather dull and text-oriented interface.
But ArchiCAD and Revit are about the same quality level. To me, these two programs are clearly the top of the crowd. I don't want to pick any of them to be the best (certainly with my limited experience in Revit and my lack of day-to-day work in ArchiCAD at the moment).
Switching, though, is not the best option. When you switch, you do it for the things you love in the other application, but you'll miss the things you liked in your current application. Just don't switch to Architectural Desktop... I have spent more time there last month then in ArchiCAD or Revit (for teaching purposes) and it was not my best time spent...
Archicad-user since 1998
my Archicad Book
