!Restored: Success = getting new customers
I saw some documents to compare between Revit and AC.
I study Revit from own website.
It is just copy from AC!!
I used to work with AC (and very satisfied, and like many friends from AC-forum).
As AC-user I hope, AC must be better than Revit for Architects.
I have not used Revit, but just seen from Website.
The web-site from Revit is so nice, that I must believe, Revit should be better than AC.
I like to know your opinions and also opinions from GS.
Thanks
368 Replies 368
Chazz
samsung wrote:
Did you make bad experiance with AC?
I have personally nice time with AC, during others had to fight with AutoCAD.....
I've used ArchiCAD for 14 years. Back then Architrion (a French 3d tool) was arguably better but it was clear AC had the momentum. Now Architrion is long dead.
These days AC still looks better than Revit in many respects but you would have a hard time arguing that Revit is not the more aggressive, focused and competent competitor. Revit has the momentum and judging from the last several releases, they will soon surpass Archicad in the BIM space. Give it another two upgrade cycles.
As I have said before, this is very much like Quark Vs InDesign a few years ago. If you are paying attention, the writing is very clearly on the wall.
Nattering nabob of negativism
Chazz wrote:
........... the writing is very clearly on the wall.
These thoughts are driving me crazy
Chazz
Joseph wrote:
30" HD Cinema Display & ATI XT800XT Mac Edition
That's what's driving me crazy.
Dwight
What pleases more?
What makes more architecture?
One big one or two smaller ones?
It's a dilemma.
Dwight Atkinson
@Dwight
What is better for rendering? AC or revit...
http://www.graphisoft-muenchen.de/buchtipp-lightworks-in-archicad-von-dwight-atkinson_tipp_2463.html
from book by Dwight
Dwight
Revit's internal rendering engine seems rather poor - comparable to the ArchiCAD Internal engine - from what I see on:
http://aec.cadalyst.com/aec/article/articleDetail.jsp?id=123082
and
http://www.revitcity.com/search.php?user_name_search=Mr%20Spot&action=searchforum
But it can export to VIZ:
http://www.caduser.com/reviews/reviews.asp?a_id=230
This makes it potentially a better file flow to a superior rendering engine to the current and in ArchiCAD 10 implementation of the LightWorks Engine.
Dwight Atkinson
Scott Davis
and
The material library that ships with Revit for it's Accurender engine is horrible. Renderings done with the 'stock" rendering materials look cartoonish. If one were to take time in Accurender to produce new materials, or modify the OOTB materials, then some really nice images can be created. Most of the stuff on RevitCity and other websites is done by people that do not take the time to do the necessary up front work. So its not really the Engine so much as it is the materials used that create not-so-good renderings.
Furthermore, Accurender is relatively slow. We have been exporting Revit models to DWG for use in Viz, and rendering with Vray and Maxwell with some nice results.
I hear Lightworks materials are really nice straight out of the box, which will help produce good renderings for everyone.
Scott Davis
Autodesk, Inc.
On March 5, 2007 I joined Autodesk, Inc. as a Technical Specialist. Respectfully, I will no longer be actively participating in the Archicad-Talk fourms. Thank you for always allowing me to be a part of your community.
TomWaltz
They are actually not that bad. Yes, they could be better, but they give a decent broad-brush palette to start with.
Tom Waltz
Revit reminds me of AC 6.5.
Revit is surely differnt concept from AutoCAD.
That means, the developement of Revit will go in the direction of Auto CAD concept.
Revit was quite unknown in europe.
Since Revit belongs to AutoCAD they are talking about Revit.
It is to consider to change just for AutoCAD user but not for AC users.
Chazz
Dwight wrote:
What pleases more? What makes more architecture? One big one or two smaller ones? It's a dilemma.
Of course it's only a dilemma of cost, not technology. I think two 30" displays is the way to go. Still, even the 2 lovely dell 20 inchers I have are great and it makes it hard to use my 15" laptop. I did not get the dell's at the same time and my productivity went way up when the second unit arrived. In terms of productivity/$, more monitor is perhaps the best buy around.
(Gosh, this post sounds neither nattering nor particularly negative. I'm gonna stop here)
