!Restored: Success = getting new customers
I saw some documents to compare between Revit and AC.
I study Revit from own website.
It is just copy from AC!!
I used to work with AC (and very satisfied, and like many friends from AC-forum).
As AC-user I hope, AC must be better than Revit for Architects.
I have not used Revit, but just seen from Website.
The web-site from Revit is so nice, that I must believe, Revit should be better than AC.
I like to know your opinions and also opinions from GS.
Thanks
368 Replies 368
I think this thread has thoroughly covered the standard features debate, and Scott is back on solid ground.
What I would really like to compare is the customization capabilities of each program. I have no experience with Revit, but I have programmed in both AutoCAD and ArchiCAD (GDL only). GDLs are very flexible, but they are only about objects. If you want to automate a repetitive or complex process, you have to use C++, which means buying a compiler.
In AutoCAD you can do just about anything with AutoLISP -- no compiler required. VBA has all the advantages of a compiled language with direct access to many (but not all) AutoCAD functions. These two systems can accommodate 99% of all the advanced user's programming needs. If you want more, there are ARX applications -- which require a compiler. Then there is DIESEL, which IMO bites.
So, what are Revit's customization options and how do they compare to GDL, Add-Ons, AutoLISP, VBA, and compiled ARX apps?
Very good question.
Revit customisation is as follows:
- Keyboard shortcuts, LOL (is this customisation?)
- Custom-built parametric objects (windows, doors, furniture, etc.) that are created graphically -- no programming language required to make these objects parametric. User-defined parameters are added that can change an object's size, material, and a host of other properties
- API accessed thru Microsoft .NET -- you write the macro and end up with a .DLL to create a command by which you can push something into the project database or edit it, or pull something out of it. So you need VB.NET, which is a few hundred dollars I believe. Learning VB.NET is not too hard, but most architects don't have the geek skillz to pull this off. Or the interest, even if they have the brains for it.
There's no macro language per se. The Revit founders were pretty adamant that the base package of Revit was not to need an API or heavy customisation -- they wanted Revit to be BIM for dummies 😉
glenn_peters
Wes… being located in Vancouver and identified as a “Revit Wishlist Manager” you may be far more familiar with the following projects than I am (please correct any mis-statements I may make…).
I have used ArchiCAD since release 4.1 (circa 1991) and have only taken a cursory look at the Revit demo software so my comparative knowledge of both is slim at best.
However, two of our former employees are working at offices where Revit is used and I had an interesting discussion with one of them a few days ago.
His firm is working on the new Convention Centre for Vancouver (an expansion of the existing facility on an adjacent waterfront site, which is being built in time for the 2010 Winter Olympics), and the entire project has been modeled in Revit Building 8.1
He notes that the scale and complexity of the model is such that they have encountered significant problems. Efforts to migrate this model to Revit Building 9.0 have failed, and Autodesk themselves have been working on the file(s) in an effort to resolve some of the operational difficulties including programme lock-up/freezing and database corruption (I am not sure of all the details).
Similarly, another firm in Vancouver has been modelling an Arthur Erickson-designed tower with a complex curtain wall system where each successive floor rotates 0.75 degrees from the one below and this same individual working on the Convention Centre has heard that the Revit model for that project is beginning to encounter similar difficulties as their Convention Centre model.
Our firm has never worked on projects of this scale/complexity so I am unable to say how ArchiCAD would fare under similar conditions. Still, it is a bit alarming to hear of these kinds of Revit problems on large projects.
It was sometimes said of Revit back when it was first released that it was not well suited to large projects… is this still the case?
Maybe the underlying Revit “engine” is not so miraculous after all?
Senior Associate, Chernoff Thompson Architects
ArchiCAD 16 (firm uses Revit)
Mac OS X 10.10 on Mac Pro (2013)
3.5 GHz 6-core Intel Xeon w/64 GB RAM & Dual AMD FirePro D700 w/6 GB Graphics
1 TB SSD w/20 TB RAID 1
Asus PB287Q 4k UHD 28-inch monitor (3840x2160)
Is Revit cheaper for this reason?
I don't believe it is cheaper. Maybe in Europe?
Revit 9 $4995
Subscription $ 695
AC +/- $4250
Subscription $ 695
Add-ons or upgrades for existing ones ?????
Cheers
Revit 9 $4995
Subscription $ 695
AC +/- $4250
Subscription $ 695
Cheers
Sorry, it was joke.
Wow, Revit is more expensive....
Krippahl wrote:
Matthew wrote:
I'll keep you all posted as this develops.
Great.
Try to talk him into sharing his experience with us here at ArchiTalk.
I'll see what I can do.
samsung wrote:
Revit 9 $4995
Subscription $ 695
AC +/- $4250
Subscription $ 695
Cheers
Sorry, it was joke.
At least you don't have to buy AutoCrap to stick it on.
__archiben
metanoia wrote:
- Plotmaker is dead. Thank God. But Revit has the project browser, which has all the views and sheets and other project related data a few clicks away. Used to be Advantage: Revit but I'd say the score is nearly even here as well.
wes - thanks for sharing your brief objective 'review'. i know very little of revit (hopefully this will change when i get my hands on a new intel mac), so it's good to hear a straight comparison of a few of the main processes. i would say, as a beta tester, that with PM dead the project browser score is also a dead heat now in ten.
Samsung wrote:
And absolutly just few engineer can understand 3D.
3D is still fantasy world for them.
whoa! no way! if anything, the structural aspects of the virtual building were accepted far far earlier than when we architects and designers decided to jump on the bandwagon! steelwork sub-contractors, for example, have been modelling right down to the last rivet and bolt for years!
~/archiben
b e n _ f r o s t
