2006-05-02 04:19 PM
2006-05-13 04:09 PM
Krippahl wrote:I used AC on some residential projects, but I don't think I had a PC up for the task at the time! Computing speed has improved so much since then (early 2001 or so).
This leads me to believe that you used AC only for drafting.
So, my quest for a AC/Revit user continues...
btw, "As a Revit moderator and AUGI wishlist manager" puts you in a odd situation regarding you alleged "hate monopolies" situation, I would think. Because, after all, Revis IS Autodesk...
2006-05-13 04:27 PM
glenn_peters wrote:MCM is working on both projects, and I've been supporting both teams. The tower project is not having too much trouble -- just keeping up with the design changes seems to be their main concern! I'm satisfied with Revit's performance on that project.
Similarly, another firm in Vancouver has been modelling an Arthur Erickson-designed tower with a complex curtain wall system where each successive floor rotates 0.75 degrees from the one below and this same individual working on the Convention Centre has heard that the Revit model for that project is beginning to encounter similar difficulties as their Convention Centre model.
Our firm has never worked on projects of this scale/complexity so I am unable to say how ArchiCAD would fare under similar conditions. Still, it is a bit alarming to hear of these kinds of Revit problems on large projects.
It was sometimes said of Revit back when it was first released that it was not well suited to large projects… is this still the case?
Maybe the underlying Revit “engine” is not so miraculous after all?
2006-05-13 05:37 PM
2006-05-13 06:14 PM
2006-05-13 06:36 PM
Thomas wrote:Microstation does handle uberprojects well. It's hard to learn it -- and are you thinking about using Microstation in 3D -- Triforma and all that? -- because that's a different matter. It's really hard to learn and use. We sell it too... but no one's buying it here.
If I'm still allowed to humbly share my opinion in this thread, I think it sounds like neither Revit nor Archicad is fully up to handling really big projects on their respective own. If I'm not misinformed, this is the area where Microstation still has a significant advantage, mostly due to its flexible way of handling reference files (XREFs). That is why Microstation is so common in large projects like airports and the like.
2006-05-13 07:47 PM
2006-05-14 03:14 PM
metanoia wrote:I'm not surprised. I switched, didn't I?
2006-05-14 04:04 PM
samsung wrote:If you want to use AC in a multi-user environment you have to purchase TeamWorks right? Revit is multiuser right out of the box, and you can use linked files just like in AC. The problem with this is that Revit users aren't comfortable with this idea because they like to be able to edit these modules more readily. Plus, you will see a joint line between these modules in elevation whereas if you don't use linked files, Revit can clean up these lines.
@Metanoia
AC has Team Works function.
This function is already enough proved worldwide.
For example the company Kajima (the biggest construction company in Japan and in the world) has proved AC.
Module is also very nice function for big or high scrapper projects.
With module you can put one storey as you put one chair in plan (small file system with link function)
2006-05-14 04:52 PM
metanoia wrote:If everybody can edit module, than it is no more module, and can be very confused to controll.
2006-05-14 07:22 PM
The problem with this is that Revit users aren't comfortable with this idea because they like to be able to edit these modules more readily. Plus, you will see a joint line between these modules in elevation whereas if you don't use linked files, Revit can clean up these lines.Modules clean up extremely well. Walls that are part of a module clean up just as easily as walls that are not in both plans and elevations.
