Reverse Magic Wand?
Does anyone know if there is a reverse magic wand function?
Let me explain a bit more. I have been busy building a terrain mesh of a golf course (pictured below) and other settings in order to create a render environment for some of my projects. I have the basic terrain done as a “master” mesh but now comes the time to add things like mulched areas (black area in the picture below) and different ground conditions. I can use the magic wand to create a hole in the “master” mesh, no problem, but when I go to fill it in with the mulch is comes in a flat surface and all the nodes are gone (as expected). What I am trying to determine is if there is a way to create a duplicate mesh to the terrain, change the surface material and the “cut-out” the opposite part that was cut out from the “master” mesh.
This example has the hole cut out of the grass mesh with a secondary mulch mesh a couple of inches below. This issue with this is the number of polygons is doubled and there are a couple of spots where the mulch is poking through where it isn’t supposed to.
2 Replies 2
Lingwisyer
Guru
Instead of cutting holes in your Mesh, you could instead use an Intersect SOE followed by a Subtraction SOE of a thick Slab or Mesh that outlines your mulch and such if it all matches your ground contours. This will also allow for adjustments in the future.
Ling.
Thank you, that worked perfectly! I knew there had to be a simple solution.
