2007-02-23 09:31 AM
2007-02-23 01:54 PM
2007-02-24 03:20 AM
t0pcat wrote:Tony, you may use my part.
I am trying to find or learn how to use a steel profile ridge capping along a ridge at a incline angle. I have a profile from lysaght but it doesn't have incline is there a way to edit it or adjust it?
2007-02-24 11:44 PM
2007-02-26 07:34 AM
Rod wrote:FYI if the library part is saved as a Roof(accessory) subtype it will automatically follow the angle of the roof even when adjusted.
Side flashing will adjust to suit roof pitch when used in either hip, ridge, or gable location.
It will do roll top metal or tiled profiles.
PM me if you need more info.
It is for AC10.
Before Djordje jumps on you please add your system spec/os to your signature.
2007-02-27 03:06 AM
t0pcat wrote:
I am trying to find or learn how to use a steel profile ridge capping along a ridge at a incline angle./....
Aussie wrote:John, when is a ridge at an incline not a hip? The maths is the same.
Further investigation is need to get the hips working.
