Roof Eaves
Is there anyway to manipulate roof eaves to make them look real.
what i do is cut a model section thru the roof eave. then with 2d lines on the model section draw the eave section exactly as you would want it. then use library parts/slabs/archiforma to create each piece of the eave. keep going back to that model section after your create each piece and drag them precisely to where they should be.
donald mac donald
Profiler works well for some of the detail you might want in eaves. It is an add-on that I believe is located in the goodies folder. I am not sure why this powerful tool is not included in the add-ons folder and loaded automatically. You will need go to the add-on manager in the tools menu to load it or move it to your add-ons folder.
