Roof Edge Textures
mrabercrombie
Good afternoon all,
I'm looking for a suggestion as to how to remedy the issue of correctly orientating a roof texture, without having to split the roof into two individual pitches. Does anyone have any recommendations?
Scott
OSx 10.6.8
3.06 GHz Intel Core 2 Duo / 6Gb Ram
Archicad 17, Archicad 17 Solo + Artlantis 4 Render
mrabercrombie
Attachment missing...
undefined
OSx 10.6.8
Did you try :
http://helpcenter.graphisoft.com/guides/archicad-17-int-reference-guide/configuration/attributes/sur...
My workflow is different because i model in AC then and i never adjust textures in AC... i adjust textures in Blender...Blender has great ability to unwrap model and you can use Photoshop for texturing. Archicad has terrible texture menu...I need to press 10 times and slide to adjust one thing....
i hope texturing is better in AC18...
enjoystick1
have you found out how to solve this? I am not able to change the orientation of the edges either (neither multi nor single plane). The command orient texture simply doesn't allow me to select the edge. Any ideas?
Petr
