‎2016-02-29
08:24 PM
‎2023-05-23
02:22 PM
Rubia Torres
‎2016-02-29 08:25 PM
‎2016-03-01 02:12 AM
‎2016-03-01 03:17 AM
Barry wrote:Unfortunately even a perfect tangential transition from straight to curve has a line at the tangent. Image below is using a Complex Profile beam.
To get an actual curve then you could try the shell tool or a complex profile wall or beam.
‎2016-03-01 03:19 AM
‎2016-03-01 03:21 AM
s2art wrote:The morph tool would fix that if it was a must.Barry wrote:Unfortunately even a perfect tangential transition from straight to curve has a line at the tangent. Image below is using a Complex Profile beam.
(PS existing building, not our design😉 )
‎2016-03-01 03:51 AM
Erich wrote:Tried to convert it to a morph, but when I deleted the offending line it took the whole surface with its2art wrote:The morph tool would fix that if it was a must.Barry wrote:Unfortunately even a perfect tangential transition from straight to curve has a line at the tangent. Image below is using a Complex Profile beam.
‎2016-03-01 04:05 AM
